99 F250 7.3L Power Steering Pump
Old Dec 30, 2008 | 08:54 PM
itismej's Avatar
Default 99 F250 7.3L Power Steering Pump
My power steering pump is starting to make noises. I checked the fluid and it is kind of a milky light brown. Don't think this is good. Maybe some water or air getting to the pump? Is there a way to bleed or change the fluid? Thanks for any info.
Old Dec 31, 2008 | 02:33 PM
bailoutnow's Avatar
Default RE: 99 F250 7.3L Power Steering Pump
Hello, you can loosen a hose near bottom of system and gravity drain, then refill (not overfill) with ford fluid. If system is noisy when turning, there may be air in system. To remove air you need: (1) extra reservoire cap that fits and seals,and a hand operated vaccum pump. Drill a hole in your extra cap just large enough to fit hose from vaccum pump. While idleing, operate vaccum pump. It can take a little while and you may want to move steering wheel from time to time. After system quiets, check fluid level, replace reservoire cap with original.
Old Jan 2, 2009 | 12:41 PM
marks460's Avatar
hi, if your power steering fluid looks like you described it -go to an oil change buisness such as jiffy lube,etc. and they will proffesionally replace the power steering fluid throughout the entire system (pump-gear sector and hydrobooster) for around $60-do not use the vaccum set up mentioned by the otherreply -you can ruin a very expensive hydrobooster that way,mark
jozepy24
Jul 13, 2019 05:21 AM
Rattler
Jul 1, 2006 02:18 PM
strider380
May 20, 2006 11:10 PM
bsmith
Apr 27, 2006 12:28 AM
bsmith
Dec 25, 2005 10:37 PM
