Hayapower |
11-19-2007 02:47 PM |
RE: 99 F350 codes, stall out wnile driving
Check the glow plug relay for burning at the studs/shunt.. Reasonably common failure.. Both banks of glow plugs need to draw 'more' than 39 amps each side or codesP01395/96 will set (Bank 1 or 2 depending) if either sidecan't make min. spec draw.. Since you have monitor fault on both banks, (P01391/93) as well as opens/low indicate the glow system to not be operational on all eight plugs.. Check the UVC connectors for burning, but with the combination of codes, would most likely not set all together.. Check for applied power to the relay for fuselink problems as well.. Could be PCM, monitor circuits ect. but check the relay straight off..
