99 F350 codes, stall out wnile driving
Old Nov 17, 2007 | 03:21 PM
wrenchman68's Avatar
Default 99 F350 codes, stall out wnile driving
CODE# PO1391, PO1393, PO1395, PO1396,
Old Nov 19, 2007 | 06:59 AM
FordNutz's Avatar
Default RE: 99 F350 codes, stall out wnile driving
http://www.svtlightnings.com/scantoo...tc%20codes.htm
Looks like glow-plug issues.
Old Nov 19, 2007 | 10:56 AM
BRETM's Avatar
Glow plug issues will not cause a stall while driving unless wiring shorts inside harness. Check your tach to see if it is getting RPM signal after it stalls.
Old Nov 19, 2007 | 02:47 PM
Check the glow plug relay for burning at the studs/shunt.. Reasonably common failure.. Both banks of glow plugs need to draw 'more' than 39 amps each side or codesP01395/96 will set (Bank 1 or 2 depending) if either sidecan't make min. spec draw.. Since you have monitor fault on both banks, (P01391/93) as well as opens/low indicate the glow system to not be operational on all eight plugs.. Check the UVC connectors for burning, but with the combination of codes, would most likely not set all together.. Check for applied power to the relay for fuselink problems as well.. Could be PCM, monitor circuits ect. but check the relay straight off..
ezra
Oct 29, 2012 11:00 AM
Fordmanxlt 31
Jun 1, 2011 09:58 PM
kisertl
Sep 14, 2010 04:02 PM
cadillac
Mar 5, 2008 09:15 PM
bluecarpenter
Jul 15, 2006 05:05 PM
