automatic high beams are dangerous
Old Dec 23, 2018 | 08:35 PM
gkraft4's Avatar
Default automatic high beams are dangerous
Ford's automatic high beams are dangerous during low visibility conditions like fog, snow, and heavy rain because the high beams reflect too brightly off the precipitation. The solution would be for the automatic high beams not to work while the fog lamps are turned on. This could be fixed by Ford through a software update.
2019 Ford F250 KingRanch PSD 4x4
Old Dec 26, 2018 | 09:23 AM
eric hoffmeyer's Avatar
Interesting. My wife's Saturn View will not allow the high beams on with the fog lamps on. 2004 model....
Old Dec 26, 2018 | 11:04 PM
Use Common Sense's Avatar
The only way I can see the fog lamps to work on the Ford with the HIGH Beams on is to have the BAMBI mode enables in the software programming (which somebody has to do after vehicle delivery from the factory). You should be able to turn off the AUTO HIGH beam option thru your screen options. Or just click the lever to LOW beams. My 2015 F-150 with AUTO HIGH beams will automatically drop to LOW beams in fog due to the back reflection unless I override the LOW beams manually.
fomenter
Dec 21, 2013 02:28 PM
tach
Aug 27, 2012 05:38 PM
MonsterG
Dec 31, 2011 06:38 PM
ironjaw
Mar 29, 2011 07:19 PM
dmac30
Apr 13, 2009 01:35 PM
