back up lights
Old Mar 10, 2017 | 01:21 PM
Kenny Trena Adkins's Avatar
Default back up lights
All........My reverse lights and "high" brake light has stopped working on my 2012 f350 extended cab truck. I have checked the #15 fuse on the passenger side fuse block (inside of cab) and found it good. While the fuse was removed, I check for power in that location and found the correct power coming to the fuse. I checked the bulbs and found them good also. With the bulbs removed, I checked for power at the reverse light bulb location and found no power coming to this location. Is there another fuse or relay between the inside passenger side fuse block and the reverse lights and high brake lights? Thoughts?
willy j
Oct 9, 2025 03:02 PM
amberblues
Dec 28, 2006 11:09 PM
F250LOVER
Jun 19, 2006 12:26 PM
BadZX2
Jun 16, 2006 03:44 PM
bastardchild
Nov 19, 2005 10:34 PM
