F-250 7.3L
Old Oct 2, 2007 | 03:00 PM
AMMO's Avatar
Default F-250 7.3L
The problem i'm having is the coolant and transmission fluid are like a milky color. Would that be a problem with the radiator?
Old Oct 2, 2007 | 03:18 PM
david paul's Avatar
Default RE: F-250 7.3L
YES THAT IS THE ONLY PLACE I KNOW THAT TRANS FLUID AND COOLANT WOULD INTERMIX THAT MEANS NEW RADIATOR TRANS FLUSHED AND NEW FLUID AND FILTER
Old Oct 2, 2007 | 03:22 PM
Sounds like a transfer leak in the trans cooler built into the radiator lower tank.. Here a pic showing the inlet/outlet lines to the cooler..
[IMG]local://upfiles/6756/63A985FB51FE432A8047148824AF8F07.gif[/IMG]
Old Oct 2, 2007 | 03:26 PM
AMMO's Avatar
Great, I'll check it out. Thanks for the help!
brobichaud
Jul 20, 2007 02:43 PM
