F250, cluster turns off, radio off, windows off, wont shift.
Old Jul 16, 2020 | 10:42 PM
Alexander Gitelman's Avatar
Default F250, cluster turns off, radio off, windows off, wont shift.
When I turned the car on, the cluster wasnt working, the radio was not working, car wouldnt shift gears, and the windows weren't working either. I turned the car off and the next day everything was working fine (except engine light). This keeps on happening, any idea as to what is going on?
Old Jul 17, 2020 | 06:52 AM
As you know intermittents can be a tech's worst nightmare.
Usually , when a component fails it fails. Questionable connections cause most of the problems
If you mean the check engine light, you might consider having a place like Autozone check your vehicle for any codes stored. They don;t charge for this.
Before you buy anything , post the codes here and hopefully we might be able to assist , maybe save you some $$$.
Old Jul 17, 2020 | 09:50 AM
Welcome to site
What year 250?
Old Jul 17, 2020 | 09:51 AM
the code I got was:
U0155 Lost Communication with Instrument Panel Control (IPC) Module
Read more at: https://www.obd-codes.com/u0155
Copyright OBD-Codes.com
Old Jul 17, 2020 | 09:52 AM
Welcome to site
What year 250?
2006 ford f250 super duty xlt. 6.0 v8 diesel.
Old Jul 17, 2020 | 10:27 AM
I’d take it in and see if they can communicate with the cluster, if not, it could be a board connection issue, or the cluster is failing.. They can be sent in for repair...
Old Jul 21, 2020 | 05:37 AM
bismic's Avatar
Power saver relay in the Instrument Cluster would be my first guess. Circuit Board Medics can repair it.
funkymm0011
Feb 2, 2024 07:04 PM
makuloco2000
Sep 13, 2020 08:30 PM
James Lockard
Mar 14, 2019 03:45 AM
echolake1
Feb 28, 2018 06:07 PM
makuloco2000
Dec 13, 2013 12:49 PM
