f250 front wheels shake bad when on a ruff road
when i drive on a ruff road my front wheels seem to go shake fast and my steering wheel shakes as well. so bad that i start to lose control of the truck this fixes by pressing the brake or steering harder to the left or right. potholessoom to make the problem worse. Dealer said it was my sterring dampner but that did not fix it. it started at 50,000 miles and now iam at 75,000 miles and steel dealing with this. since i got larger tires it has gotten even worse. I dont want to have an accident over this so iam hoping some one knows what it is. I see lots of posting for this issue but they are old with no real fix.
Anyone out there know what i can look into? cause even the dealer is clueless!
heres what autozone.com says (i estimated the year and guessed it was 4x4)
Inspect
Wheel Nut
Loose or missing wheel nut(s).
89
Inspect
Wheel Stud Torque
Improperly torqued wheel nut(s).
1617
Inspect
Brake Rotor Specs (Min Machining)
Component warpage/wear beyond allowable limits
2425
Inspect
Brake Drum Specs (Max Machining)
3233
Inspect
CV Boot Kit
Dry, damaged or worn cv joint caused by leaking cv boot.
4041
Inspect
Ball Joint - Lower
Worn or damaged lower ball joints
4849
Inspect
CV Halfshaft
Dry,Worn or damaged cv half-shaft
5657
Inspect
CV Halfshaft (Reman) CVJ
6465
Inspect
Strut Rod Bushing
Broken or damaged strut rod bushing
7273
Inspect
Wheel Bearing - Front
Worn or improperly lubricated wheel bearing.
8081
Inspect
Tie Rod End
Loose, worn or incorrectly adjusted tie rod end(s).
Inspect
Wheel Nut
89
Inspect
Wheel Stud Torque
1617
Inspect
2425
Inspect
3233
Inspect
CV Boot Kit
4041
Inspect
Ball Joint - Lower
4849
Inspect
CV Halfshaft
5657
Inspect
6465
Inspect
Strut Rod Bushing
7273
Inspect
8081
Inspect
Tie Rod End
Did you put a lift kit on your truck? If so, did you have the front end aligned after the lift was installed? How are your front tires wearing, are they wearing evenly?
Man i am having the same trouble. i just bought a f250 with a factory 4" suspension lift. When i hit a bump the front right tire starts shaking so bad i almost loose control. I had to front stabilizer shock replaced to but still didnt fix the problem. Have you figured out a solution yet?
