Constant sourse of 12 voltage
Old Oct 12, 2007 | 07:42 PM
johndeere88's Avatar
Default Constant sourse of 12 voltage
is there anywhere else besides the battery that i can find this?
2001 Ford f-350 XL
Old Oct 12, 2007 | 07:54 PM
david paul's Avatar
Default RE: Constant sourse of 12 voltage
WHAT R U WANTING IT FOR IF ITS INSIDE CABE USE POWER POINT WIRE IF AT REAR OF VEHICLE THERE IS A WIRE IN THE WIREING HARNESS THAT IS HOT WITH IGNITION ON THAT IS FO ACC. LIKE BATTERY CHARGE FOR WINCH BATTERY OR OTHER USES
Old Oct 12, 2007 | 07:59 PM
its for the control module for power locks and where do i connect it to if im using it off the power point
Old Oct 12, 2007 | 08:26 PM
david paul's Avatar
JUST UNPLUG WIRE FROM BACK OR POWER POINT SPLICE INTO IT THEN U CAN PLUG BACK UP THE POWER POINT THAT CIRCUIT SHOULD CARRY IT ALL AS THEY WON'T BE A CONSTANT LOAD ON IT
Old Oct 12, 2007 | 10:42 PM
are u talking about the powerpoint on my dash?
Old Oct 13, 2007 | 07:13 AM
david paul's Avatar
YES
FordMan59
May 1, 2009 03:25 PM
jjam20
Oct 28, 2008 08:39 PM
jjam20
Mar 29, 2008 02:32 PM
ghostpoet
Sep 25, 2005 06:40 PM
sardines311
Feb 24, 2005 02:48 PM
