Ford f250 7.3L V8 drinking oil
Old Mar 7, 2011 | 07:27 AM
SHOIAN's Avatar
Default Ford f250 7.3L V8 drinking oil
Hello, I recently bought a 88 F250, 460 v8, runs great lots of power, but for some reason it's using a lot of oil. There's no smoke and no apparent leaks. Example: I'll check the oil its full, then drive about 20 miles check again it's 1-1.5 qts low. Refill and the process repeats.
Old Mar 7, 2011 | 01:38 PM
The oil has to be going someplace. How is the coolant?
Old Mar 8, 2011 | 03:21 AM
SHOIAN's Avatar
Hello Hanky,
Thanks for responding as far as I can see the coolant is fine, I plan to flush the entire system. I'm not over heating, it's not frothy or the oil dip stick. It looks feels and smells like coolant. I do need a heater core though. This is a mystery
Old Mar 8, 2011 | 03:21 PM
Did you check out the crankcase vent system?
Did you actually get under the truck and see if the oil is getting blown somewhere?
Old Mar 9, 2011 | 08:14 AM
SHOIAN's Avatar
Good morning, Hanky,
Yes I looked under the truck it looks about the same as my 2000 chevy that's not using oil. I took it to a mechanic that works on late model 4x4 and it's puzzling him. He's doing a compression test today. He said this truck came from California all of the emissions stuff is still on it, how well it works or if it working against I don't know. Forgot to mention it's a 3 speed trans don't know what the rear is. I drove it About 60 miles at speeds no higher than 55 mph and the truck use 12gl of gas and 1 qt of oil. As of right now it appears that truck just uses 1 qt per day. I'll keep you posted on any new developments.
Old Mar 9, 2011 | 02:58 PM
I just noticed something and that is your thread states a 7.3 which I assumed was a diesel. And yet your 1st post states it's a 460 CID. It probably is a candidate for rings and/or valve seals. The compression test should help eliminate the possible ring problem.
The 460s were never that great for gas mileage. That's a big mouth to feed and it eats gas.
jcasaccio
Oct 7, 2018 08:02 AM
cedar8411
Nov 8, 2012 08:24 PM
AZ Dude
Aug 23, 2010 04:26 PM
kustomkid18@aol.com
Mar 24, 2009 08:32 PM
Aphotic
Nov 18, 2008 04:09 PM
