front axle seals
Old Nov 3, 2007 | 09:21 AM
brandon's Avatar
Default front axle seals
between both cv joints and axle housing on the front end, there is what looks like a piece of the seal just hanging there. is this normal? it looks like the right side has been leaking but the right side is fine.
Old Nov 5, 2007 | 02:08 PM
Default RE: front axle seals
Very common for both the axle to hub/spindle seal to loose a 'ring' as well as the axle to tube dust seal to loose the outter most portion of the seal.. If gear lube is leaking down the axle tube, the inner axle seals will need to be replaced from inside the diff case.. The axle tubes should be cleaned of debris during a re-seal so not to push debris into the new seals, or to cause premature seal wear...
Jackpot
Apr 22, 2014 12:40 PM
flamingitaur
Oct 24, 2010 01:47 PM
jz57_cn
Mar 17, 2007 09:29 PM
pilotlars
Aug 8, 2006 11:04 PM
