Fuel Gauge Issues
Old Jun 11, 2022 | 01:10 PM
Connor Lindsey's Avatar
Default Fuel Gauge Issues
Hi, I have been having an issue in my 1986 Ford F-250 with the fuel gauge not reading out, I’m newer to working on fords and could use some help on where to start if anyone has any idea, thank you.
Old Jun 12, 2022 | 05:32 AM
raski's Avatar
You need to be more specific. Is it stuck on empty, full or something in between? If you can remove the signal wire off the sending unit somewhere, the gauge should swing as far as it can to the full side. An open sending unit or a break in the wiring will have the same effect.You can also try tapping on the tank with a rubber mallot to see if the swing arm for the float is stuck.
Revived
May 13, 2017 05:59 PM
mike1589
Jan 17, 2010 11:39 AM
gunner360
May 11, 2008 06:55 PM
ryanflatt
Jul 27, 2007 06:27 AM
tfunk002
Dec 26, 2006 09:24 PM
