Help!!!! F250 running rough!!!
I have a 2005 F250 5.4 3v 139,000 miles. I’m throwing codes P0012,( intake (A) camshaft position timing over retarded bank 1) P0022. ( intake (A) camshaft position timing over retarded bank 2)
I’ve replaced all 8 plugs with new motorcraft plugs, all new coil packs, replaced fuel filter, installed both VVT’s and both camshaft sensors. I’ve cleaned the MAF and the throttle body. The truck is running rough with no misfire codes. Has smoke coming from the exhaust with a lot of condensation. As far as I know the engine coolant remain full as I can see it from the coolant tank. The truck sat for about a year or so. |
Welcome to the site..
What did the plugs look like when removed? Meaning, any collections there or indication of burning coolant or oil? If coolant, any bubbling in the degas bottle? The tail pipe emissions smell sweet, don’t dissipate quickly? On the codes, VCT solenoid stuck open possibly,, but probably not L&R fails simultaneously. VCT’s binding.. what’s the engine oil look like? |
(Post 108249)
What did the plugs look like when removed? Meaning, any collections there or indication of burning coolant or oil? If coolant, any bubbling in the degas bottle? The tail pipe emissions smell sweet, don’t dissipate quickly? On the codes, VCT solenoid stuck open possibly,, but probably not L&R fails simultaneously. VCT’s binding.. what’s the engine oil look like? The plugs looked bad. Black looking. Looked like they have been in there a while. I know the previous owner said, they’ve replaced the plugs twice and they kept fouling out. The smoke out of the exhaust kind of smells like old gas/fixed with oil. I’ve drained the oil pan and did a fresh oil change and filter. The old oil look really black and thin. I’ve checked the coolant tank for bubbling. No bubbles. The coolant level stays where it’s supposed to be. |
Originally Posted by aramsey08
(Post 108261)
The plugs looked bad. Black looking. Looked like they have been in there a while. I know the previous owner said, they’ve replaced the plugs twice and they kept fouling out. The smoke out of the exhaust kind of smells like old gas/fixed with oil. I’ve drained the oil pan and did a fresh oil change and filter. The old oil look really black and thin. I’ve checked the coolant tank for bubbling. No bubbles. The coolant level stays where it’s supposed to be. https://cimg2.ibsrv.net/gimg/www.for...1bc5bd817.jpegThis is the new plugs after about 20 minutes of running. https://cimg5.ibsrv.net/gimg/www.for...041182e1f.jpegThis is the new plugs after about 20 minutes of running. https://cimg6.ibsrv.net/gimg/www.for...a5fd003e0.jpegThis is the new plugs after about 20 minutes of running. https://cimg7.ibsrv.net/gimg/www.for...34a42cc92.jpegThis is the new plugs after about 20 minutes of running. https://cimg8.ibsrv.net/gimg/www.for...f1d561000.jpegThis is the new plugs after about 20 minutes of running. https://cimg9.ibsrv.net/gimg/www.for...6134f8588.jpegThis is the new plugs after about 20 minutes of running. https://cimg1.ibsrv.net/gimg/www.for...de9f48fbe.jpegThis is the new plugs after about 20 minutes of running. |
Wow, he has everything there !
What are your thoughts, fluctuating oil pressure intake manifold problem noticed what appears to be a lot of never-seize there, maybe too much? Hope you don't mind my asking some questions, thanks. |
To me it looks like the plug fouling gets worse from cylinder #4 towards #1. Cylinder #5-8, pretty good with 5 & 6 looking the best and having the least amount of anti-seize on them. I would start by cleaning off as much anti-seize as possible.
Are you using aluminum or nickle based anti-seize? I prefer nickle based in high temp applications due to its higher heat range capability. I've had too many plugs that had aluminum based anti-seize on them that just would not budge. If you don't want to use nickle, use copper based anti-seize on your plugs, but a very, very thin coating of anti-seize. Also, if the truck sat for a year, was the fuel replaced? |
Hard to ignore the codes for cam problems, just find it difficult to explain why some are rich, some appear coolant contaminated, and some are fine. Could be wrong, but probably have more than one problem here.
(Post 108273)
What are your thoughts, fluctuating oil pressure intake manifold problem noticed what appears to be a lot of never-seize there, maybe too much? Hope you don't mind my asking some questions, thanks. Cylinder 1) No reading on the gauge, but I put a rubber heater hose into the plug well to see if air comes out. Which it does but maybe not enough to register on the gauge. Cylinder 2) 181 Cylinder 3) 183 Cylinder 4) 183 Cylinder 5) 181 Cylinder 6) 181 Cylinder 7) 181 Cylinder 8) 182 |
Originally Posted by Use Common Sense
(Post 108277)
Are you using aluminum or nickle based anti-seize? I prefer nickle based in high temp applications due to its higher heat range capability. I've had too many plugs that had aluminum based anti-seize on them that just would not budge. If you don't want to use nickle, use copper based anti-seize on your plugs, but a very, very thin coating of anti-seize. Also, if the truck sat for a year, was the fuel replaced? Cylinder 1) No reading on the gauge, but I put a rubber heater hose into the plug well to see if air comes out. Which it does but maybe not enough to register on the gauge. Cylinder 2) 181 Cylinder 3) 183 Cylinder 4) 183 Cylinder 5) 181 Cylinder 6) 181 Cylinder 7) 181 Cylinder 8) 182 |
(Post 108291)
I’m using nickle based anti-seize. The truck had less than a 1/4 of a tank. I bought Seafoam and put half of the Seafoam with $25 in gas. I did a compression test on it today here are the “DRY” readings. Cylinder 1) No reading on the gauge, but I put a rubber heater hose into the plug well to see if air comes out. Which it does but maybe not enough to register on the gauge. Cylinder 2) 181 Cylinder 3) 183 Cylinder 4) 183 Cylinder 5) 181 Cylinder 6) 181 Cylinder 7) 181 Cylinder 8) 182 |
