Hi, mysterious miss at 1-1.5 k rpm
Old Apr 10, 2007 | 10:30 PM
  #11
racinteach's Avatar
Default RE: Hi, mysterious miss at 1-1.5 k rpm
gonna try that ..picking up some motorcraft plugs right now....and going to repalce the coil as well.the plug was just wet....I think they were in longer then the guy said...I think it cracked when I was trying to get my toy hauler up a hill..when it started
Old Apr 11, 2007 | 02:36 AM
  #12
racinteach's Avatar
ok our compression test was strange..could not get teh hose to fully seal..lots of air came gussing out and the dial read 40....two ideas..
bad valve, or cross threaded spark plug....the spark plug caem out wet but not sure what it was that was on the threads...yes the threads...the threads were coated all the way up..no other cylinder had oil or liquid on it..what you think? and by the way thank you for your help......
Old Apr 11, 2007 | 03:28 AM
  #13
The new plug came out wet?
If the new plug came out wet after the engine was run, I'd be inclined to get a more accurate reading if possible.. Especially after a plug/coil change and if the misfire is still present.. Does the plug look, or smell like raw fuel?
Old Apr 11, 2007 | 12:31 PM
  #14
racinteach's Avatar
did not smell like gas...the new plug was not soaking like the first plug that was originally in the cylinder...I removed another plug to compare...it had no oily resedue on it at all. However the originalone had it up the threads..the compression hose would not seat on this cylinder either...we checked the coils for spark ...all of them had good spark..so my two ideas are : cross threaded ill seated plug..or bad valve or rings...gonna take it in today to have it diagognossed properly at a shop..I have runout of time to get this guy going right again..Without a scanner I am shooting in the dark and if it's a ring or valve..the scanner ain't gonna help.. thanks for your help ..I heard these were bullet proof engines..guess one toy hauler trip and it could not handle the load..
Old Jun 4, 2007 | 06:28 AM
  #15
FordNutz's Avatar
I'm having a similar problem. I've changed all the plugs w/ autolite double platinum as the book calls for. It cleared this problem up for about 2 weeks. Now it idles fine, runs rough up to 30 mph, and clear up to 75mph or higher. When i step on it and it downshifts, the engine cranks right up with all the power you need. Just seems like it runs 1 cylinder short through mid range. All the plugs that I took out looked like they burn well,( very light brown). I do not get a CE light but the bulb isnt blown so I know that much. Any ideas if this may be the same problem? Should I make my own thread?
Old Jun 4, 2007 | 08:29 AM
  #16
racinteach's Avatar
ok update...about 2k later I have my truck back. Turns out I lost number three valve. tulliped is what they say..apparently a common issues with this truck...so it was redone and now I have my truck back......
HorchataKing
Sep 3, 2009 06:44 PM
2001f250
Nov 30, 2008 01:25 AM
stash3123
Jan 17, 2008 06:31 PM
Damian1982
Jul 13, 2007 07:16 AM
daveranger
Dec 4, 2006 12:01 PM
