Left Rear Brake and Stop Light Not Working
Old Apr 9, 2025 | 01:42 PM
MRMAJESTIC's Avatar
Default Left Rear Brake and Stop Light Not Working
When I step on the brake or use turn signal, the left rear brake and turn single does not work but the driving and reverse lights work okay. Also the other side works okay. Left mirror and front lights work okay...all the lamps are checked and okay and wires look good.
I used ForScan to clear any BCM codes with no luck.
Any suggestions?
Thank
Old Apr 9, 2025 | 02:30 PM
You said you checked the lamp and the wiring and they are good, so swapping the left to right should work. Try it. It's a 3157 bulb right?
Tattedchick
Jan 28, 2022 10:18 AM
Stephen Green
Jan 10, 2020 12:47 PM
repotowman52
Feb 23, 2019 09:28 AM
Cmarotta870
Feb 27, 2009 07:05 PM
longwolf
Dec 17, 2008 12:14 AM
