Lifting a Ford F-250 Superduty
Old Aug 14, 2009 | 11:37 AM
mjmancus's Avatar
Question Lifting a Ford F-250 Superduty
I recently purchased a 2006 F-250 with a 4" lift on the front. After inspecting it, I discovered the back is sitting just under an inch lower than the front. So I want to lift the back, so in looking at adding a leaf spring in the back they have two, one set is a 1 inch lift the other is 2 inch. But I am sure with everything they do not give a true 1 or 2 inch lift. Which should I go with?
Old Aug 15, 2009 | 08:48 PM
JTGrant1's Avatar
If you want a cheap 1" lift ide just cut another leaf from an old one, and add it to the existing stack. It's the easiest, and cheapest way to level out 1-2 inches.
mjmancus
Aug 14, 2009 11:20 AM
flatheadfooser
Aug 12, 2007 11:57 AM
drw0392
Dec 25, 2006 06:18 PM
jasper
Dec 12, 2006 08:23 PM
ryanflatt
Apr 8, 2006 07:32 PM
