no lumbar or cruise control
Old Oct 25, 2006 | 12:41 AM
93f250xlt4x4's Avatar
Default no lumbar or cruise control
my 1993 f250 xlt 4x4, the lumbar doesnt work theirs no sound coming out of the air pump or nothing. also my cruise control doesnt work. please help
Old Oct 25, 2006 | 05:57 AM
94 4x4 ranger's Avatar
Default RE: no lumbar or cruise control
Did you try checking the fuse's?
Old Oct 25, 2006 | 09:32 PM
yes and the fuse for the cruise control would affect the horn and the horn works. also for the lumbar the fuse isnt blown
Old Oct 26, 2006 | 10:59 PM
masterexploder's Avatar
i believe that the lumbar motor is under the seat, try and hit it with a hammer while pushing the button and it may jump start the motor again, and there is a cruise deactivation behind the brake pedal pull it off, then drive it while holding down the switch, activate the cruise and see if it works, if it does replace the switch. it gets kind of tricky holding the switch while driving and activating cruise so do it somewhere that there isn't a lot of trafic
Old Oct 27, 2006 | 12:16 AM
thanks so much i will try that
Old Oct 27, 2006 | 12:43 AM
allright ive tryed tapping it with a hammer and ive also rechecked the fuses. nothing happened i didnt check for the cruise control since its 11 atnight.
Old Oct 27, 2006 | 11:06 PM
alright then if you have a test light connect it to ground disconnect the connector going to the lumbar motor turn the key to the on position and hold down the switch for the lumber, touch the test light to the leads if one lights up the test light that means that it is gitting power and you need a new motor if it doesn't light up than you have a switch or wiring problem. if you don't have a test light i suggest you buy one they are onlyabout $10-15 at any auto parts store and they are really handy when diaging any electrical problems
Old Oct 28, 2006 | 12:37 AM
allright i will try that. how much does one cost anyways(motor)
Old Oct 30, 2006 | 11:04 PM
hey i also found an old recall for it that may pretain to why it doesn't work, but it probably doesn't, sorry it is hard to find a price on one.
Auto Recall Date: 04/16/1996
Vehicle Component: SEATS
Estimated Vehicles Affected: 31000
1994 FORD F250 Defect Summary:
THE WIRE HARNESS FOR THE POWER LUMBAR FEATURE ON THE SEAT IS UNDERNEATH THE FRONT SEAT CUSHION SUPPORT WIRES. THE SUPPORT WIRES ON THE DRIVER SEAT CAN CONTACT AND DAMAGE THE INSULATION HARNESS RESULTING IN A HIGH RESISTANCE ELECTRICAL SHORT THROUGH THE SUPPORT WIRES.
Defect Consequence:
CONSEQUENCE OF DEFECT: OVER HEATING OF THE SUPPORT WIRES COULD RESULT, AND MELTING, SMOKE, OR POSSIBLE IGNTION OF THE SURROUNDING MATERIALS COULD OCCUR.
Remedy:
DEALERS WILL INSPECT THE SEATS ON THE AFFECTED VEHICLES. IF NO DAMAGE IS FOUND, THE DRIVER SEAT WIRE HARNESS WILL BE COVERED WITH A PROTECTIVE CONVOLUTE TUBING, WRAPPED WITH ELECTRICAL TAPE AND THE HARNESS WILL BE REROUTED. IF DAMAGE IS FOUND, THE WIRE HARNESS WILL BE REPLACED.
Notes: FORD MOTOR COMPANY,
Old Nov 28, 2007 | 06:41 PM
mick's Avatar
My 1996 F-350 has a lumbar that doesn't inflate, though the air compressor runs when I push the button. Do you think the bladder blew out?
