No running lamps no tail lights no instr lights
Hey Laura, just as a side thought I have had, if you live in CA I believe you now qualify as a lemon car. Same problem 3 times to the dealer constitutes lemon by CA law. You will need to look into it a bit further but the dealer should now be responsible for all costs of repairs. Again I'm not 100% but it is worth looking into. Sorry to hear about all your problems.
I'm having the same issue. All fuses are good, and all relays I can access check out. Everything on the trailer plugs and trailer works, but I have no park lights on the truck. The brake and turn signals work, and the park lights on the LED mirrors work. Both the run lights are none. I can power up the circuit from the rear tail light with a power probe and all lights come on. The headlight switch is good. So there's gotta be some sort of junction box or relay I'm missing.
