P02EE Code, Injector #1 Circuit Range/Performance
Old Sep 9, 2021 | 10:54 PM
A_F350's Avatar
Default P02EE Code, Injector #1 Circuit Range/Performance
Trying to resolve the DTC code above. The issue first started about week ago while cruising around 55 mph. The truck started running rough and felt under powered when going up slight inclines or at low RPMs in higher gears. I could not recreate the issue after getting home and started trouble shooting it later that evening. No error code was generated after that event. Today, a similar event happed while driving. After starting up the truck 7 hours later, it ran rough at start up and has continued to do so. This evening I plugged in my code reader and recorded the information before clearing the DTC's. I pulled the wiring harness off the #1 injector and it had some moisture in it so I used a compressor to blow out the moisture on both fittings and reconnected. That did not change the way the truck ran, though a code was not generated when I drove about 10 miles on the highway. The truck is a 2012 F 350, 6.7 with 181,000 mi.
Thanks for the help
icrash2often
May 8, 2017 04:21 PM
oldtrumpet
Jan 17, 2016 06:38 PM
4gethernot
Feb 21, 2014 12:12 PM
luvnlyf1
Dec 22, 2012 01:42 PM
61 2DOR
Oct 10, 2011 10:46 AM
