Pass. Side Window Not working/Driver's door wiring harness broken wire
Ford F-250 & Ford F-350The heavier duty full sized trucks from Ford, offering bigger, more powerful engines and drivetrains for the abuse they may go through in the workplace.
So my passenger side window will not go back up once it is put down. I have done quite a bit of tracing and found there is a short or broken wire of some kind just inside the boot in the driver's door right next to the male end of the wiring harness. Any way that I can remove the good without tearing it or cutting it? Or is there a way to go in and solder a jumper wire in on the passenger side to manually override that ? I would just buy and install a new harness but they are on back order with no date on when they will be available.
