Possible exhaust back pressure problem?
Old Dec 12, 2009 | 09:59 AM
  #11
surreyboy's Avatar
Originally Posted by Beater
What is the actual name of the sensor on the front of the motor by the water pump? I unplugged mine and the problem you described went away. The air intake sensor is fine. I asked the dealer to check out the problem last week when the fuel heater shorted and left me on the side of the road but they didn't. Guess they need another hour of diagnostic, wouldn't want to fix two problems at once! Does that pipe plug up often?
Nate
99 F350 7.3L
"does that pipe plug up often"
im no mechanic but from my understanding the tube will build up with carbon from letting the truck iddle for long periods of time . at my house this morning the temp was -30 degree C so i would let the truck warm up for atleast half a hour . hope that helps
Old Dec 21, 2010 | 06:26 PM
  #12
99450's Avatar
Well, I hope you are correct about unpluging the ebp valve at turbo. I unpluged mine and my truck runs like new again. Please inform if you have any problems with issues this may result in.
Old Feb 25, 2014 | 01:37 AM
  #13
sirgino's Avatar
Default Jake Brake sound
I'm having exactly what you're describing on my 97 F-250 7.3L and was wondering if you ever found the problem. While I'm not hearing the jake brake sound now that I've disconnected the ebps, - or at least that 's what I think that was - I still feel it dragging the engine down as though I'm in second gear all the time. Would appreciate any input you may have. Thanks
Jdubu420
Sep 3, 2013 05:55 AM
Jagerblunt
Aug 16, 2013 06:42 AM
epm103
Feb 3, 2012 08:08 PM
3rd Dan
Jun 9, 2008 02:20 PM
F250LOVER
Jun 19, 2006 12:26 PM
