Problems with the 6.4 in the f250
Old May 14, 2019 | 06:17 PM
Lane McAlexander's Avatar
Default Problems with the 6.4 in the f250
Was wondering what the issues were with the f250 6.4
Old May 19, 2019 | 08:08 AM
ka9j's Avatar
I don't have a 6.4, so this isn't first hand, but from things I've read.
6.4's use the back 2 cylinders to regenerate the DPF, so the back 2 cylinders get very hot every time. The problems this causes is that the back 2 cylinders experience a lot of wear, and this causes the bore to wear away completely removing the cross hatch on the bore. The cylinder heads also crack, and it's getting harder and harder to find replacements. There are only 4 head bolts per cylinder, so head gaskets often leak, allowing coolant to enter the cylinder.
Go to powerstrokehelp.com and you will see a lot of videos and information about all the Ford diesels.
If you're thinking about buying a 6.4 you probably want to talk yourself out of it.
Old May 19, 2019 | 04:20 PM
frankjr's Avatar
Default 6.4 status
I found a much better explanation of why you shouldn't buy a 6.4L Ford.
Old May 23, 2019 | 10:26 AM
bismic's Avatar
LOL, I wonder what poor Bill really thinks!
JWStiles65
Nov 7, 2017 03:23 PM
Cole Olberding
Apr 23, 2016 09:38 AM
Jonathan Anderson
Apr 10, 2010 02:04 AM
fastvee
Jan 21, 2008 11:32 AM
evil_redneck
Mar 23, 2006 10:19 PM
