Radio
Old Dec 12, 2007 | 12:03 PM
Easy's Avatar
Default Radio
I would like to get a different radio. How do I get the factory radio out fo my 2007 F250?
Thanks
Old Dec 12, 2007 | 01:03 PM
Default RE: Radio
The complete instrument finish panel needs to be removed.. Snaps to the dash, and then the electrical connectors removed.. Then remove the attachment screws connector ect. to remove the radio..
Old Dec 12, 2007 | 01:55 PM
Easy's Avatar
Default RE: Radio
Thanks for the response. How do I get the instrument finish panel off? Are there any photos to show the clips or attachment points? The wiring is a piece of cake I'm afraid of breaking the instrument panel.
Thanks
Old Dec 12, 2007 | 02:51 PM
Default RE: Radio
The finish panel removal is really fairly easy.. I usually start at the left side, andpull straight 'outward' on the panel, working my way around 'evenly'.. Pull only far enough to release the clips.. It's pretty solid,and can easily be done by hand, or if you have a hook ect. you can slide it around the back for a gentle pull and release more at the clip/attachment points.. The area close to the steering column sometimes has the hardest release since the area to pull is harder to grab, and you don't want to bow, use the panel as leverage to getit loose there.. If your just pulling the radio, once the finish panel is loose, you can lift the panel on the passenger end and support it, so not to have to release all the connections.. Some have connector locks.. Here an exploded view of the dash ect. I marked 'most' of the clip points..
[IMG]local://upfiles/6756/CD8B408F14DD4FD189B1D2909BE2249A.gif[/IMG]
Old Dec 12, 2007 | 03:02 PM
Easy's Avatar
Default RE: Radio
Thank You For The Info !!!!!!!!!!!!!!!
kneivel
Feb 15, 2023 05:30 PM
b3n129
Sep 20, 2008 05:59 AM
roundman
Jan 25, 2006 05:25 AM
steven
Feb 28, 2005 07:16 PM
