remove caliper
Old Mar 26, 2008 | 05:58 PM
nascar_fan28's Avatar
Default remove caliper
whats best way to remove caliper.. got the 2 big bolts off.. but it wont slide.. do i need to compress, and whats best way.. this is rear brake on 2005 f350 single rear tire
Old Mar 26, 2008 | 06:20 PM
Default RE: remove caliper
Mosttimes you can just pull hard on the caliper (towards yourself) and it'll compress the piston enough to slide the caliper off.. Or, you can use a small pinch bar/larger screwdriver and pry between the outer caliper (facing you where the outboard pad fits/mounts)and the rotor surface to push the piston back..
Old Mar 26, 2008 | 07:32 PM
jr78's Avatar
Make sure you compress that caliper some first, as I think the pads have a couple of pins inthem that will break the caliper pistons if you try to pull it off without compressing
Fredo
Oct 9, 2007 07:38 AM
dabeatcreata
Aug 24, 2007 11:33 AM
dabeatcreata
Aug 24, 2007 06:50 AM
lauk101
Oct 4, 2006 08:54 AM
redskins13
Sep 9, 2006 06:07 PM
