So you think you can troubleshoot do ya!?
Heres the deal, 2004 F250 PSD
Everything was working 100 % on this truck,no issues at all. I swapped out the headlights for some HID's and LED Blinkers with regular parking lamps. Install went fine, all wiring is perfect have checked it 50 times. Problem is, now I have no running lights. Everything works including the trailer lights, just not my front, rear, and license plate running lights. I have checked every fuse atleast 10 times, replaced every relay in the fuse panel under the steering column, and checked the others next to my ECM under the hood. When I put power directly to the brown wire on the front running light from the battery, they all light up perfectly. I have power from the brown wire at the switch also, both brown wires actually. I cant locate the "Park Lamp Relay" does anyone know where this bastard is hidden. I have read every post on this I could find, and havent got an answer yet!! So to recap
1. Have power at switch
2. Have power at trailer harness
3. All fuses are good
4. Everything works except front and rear running lights on truck and license plate lights.
5. When power is put directly to brown wire, everything lights up fine.
Thanks in advance!
Thanks in advance!
loseraic
Jul 22, 2018 04:33 PM
nickfordf150
Aug 29, 2011 01:55 PM
