Spark plug change
Old Jan 30, 2008 | 06:33 AM
loomis's Avatar
Default Spark plug change
My '01 V-10 Supercab has 99k miles now and is approaching the recomended spark plug change interval. I am concerned about plug blow-out after the change. Any tips/tech information on how to change the plugs and prevent this problem would be appreciated.
Should I even change the plugs now? This truck runs great and gets relatively good fuel economy for a big 4x4--13.5-15.5 mpg. and has no miss or start problems.
Also, does one replacement plug perform better than the others? My primary interest is fuel economy, I seldom use all the power this thing makes!
Old Jan 30, 2008 | 09:16 AM
david paul's Avatar
Default RE: Spark plug change
let me know also
Old Jan 31, 2008 | 09:20 PM
btexpress's Avatar
#!. DO NOT USE BOSCH SPARK PLUGS!!!!!!!
#2 Blow any dust or debris out of the plug cavities BEFORE removing the spark plugs
#3. Use a quality anti-seize compound on the plug threads, just a little, don't overdue it
#4. Torque the spark plugs to Ford specs.
#5. Pray to the spark plug Gods
#6. DO NOT USE BOSCH SPARK PLUGS!!!!!
Old Aug 3, 2008 | 03:15 PM
resse13's Avatar
why not bosch? i just bought the bosch iridiums, and have not put them in......
Old Aug 4, 2008 | 12:35 PM
jwko's Avatar
The Bosch plugs with the mutiple ground electrodes causes problems with Ford's computer controled electronic ignition. I don't see any problems using Bosch single grounding electrode plugs. I wouldn't wait 100k next time to change them out, maybe 30 to 40k.
Old Aug 4, 2008 | 09:13 PM
resse13's Avatar
well that sux. i just installed a set of bosch fusion. took forever. i hope i dont have any issues......
Old Aug 8, 2008 | 07:36 PM
resse13's Avatar
so far so good. noticed alot more pep, and better milage.....
Old Sep 6, 2008 | 09:24 AM
jvcski's Avatar
I have an 04 250 and I actually had a plug blow off my truck yesterday. I had a noise that started like a ticking, lifter noise or small exhaust leak or so I thought. I was on my way to work and POP!!! thought I snapped a rod but had it towed to my trusty garage and sure enough blew #7 third one back on the passenger side. which come to find out my mechanic friend has done about 35 of them!!!! I would do them at 100000miles and I am pretty sure the torque specs are 11lbs but after you change them give it 2 weeks and check them again. a lot of times they are over tightened and it is only and aluminum block, so the threads strip out. GOOD LUCK and GAS ON!!!
mardyel
Sep 23, 2025 05:41 PM
94E350
Nov 28, 2011 03:54 AM
fordmjb
Feb 26, 2008 09:12 PM
Beater
Jun 20, 2007 04:47 AM
kpmalone
Nov 19, 2005 10:42 AM
