starter problems
Old Jul 4, 2007 | 11:46 PM
shordinges's Avatar
Default starter problems
the starter wont turn at all, i have replaced the celinoid, pulled out the starter to test it and everything works, but when i install it into the 460 when i try to start the truck the celinoid goes click but no response at all from the starter motor, i have checked all of the connections (positive power and ground) and themy voltagetester says its all getting power. if i unbolt the starter from the motor but keep the power wire on and ground the case to the negative battery terminal the starter still doesnt respond so i know that its not from the motor keeping it from turning. i have taken the starter out and just straight wired it to the battery and it engages well. i have checked the connections many times but i am so confused on why it wont try turning while going by the connections from the truck. (1990 f-250 lariat 460 EFI) thanks
Old Jul 5, 2007 | 08:44 AM
FordNutz's Avatar
Default RE: starter problems
Ever check the starter relay on the fender? Also very low amps in a dying battery can cause the symptoms you describe.
Old Jul 5, 2007 | 02:54 PM
shordinges's Avatar
isnt the cilinoid and the starter relay the same thing? and i had a friend of mine jump my battery so i know its not froma lack of power
Old Jul 9, 2007 | 10:04 AM
domesticfan's Avatar
if a battery is weak enough, Jumping it wont help. i tried it on a friends car it wouldnt start till we put a new battery in.
purefury
Nov 26, 2007 06:07 PM
turbo79
May 18, 2007 10:10 PM
abebi_dark_angel
May 11, 2007 08:18 PM
fosterjef
May 6, 2007 06:21 PM
jdm
Feb 26, 2006 08:38 PM
