Starter sticking on power stroke
Old Dec 5, 2007 | 09:57 PM
outboardman's Avatar
Default Starter sticking on power stroke
I have a problem with a '96 f250 7.3 power stroke. Once the key is turned the starter will keep running (cranking the engine). I have replaced starter sol. assy. slave sol. assy. ( in outboards I have had a ton of these stick on) After doing all that the dang thing still will not stop. The only way it will quit cranking is to pull the battery wires off. Now sence it has done this I have not been able to get it running but I have not tryed. don't want to burn out the starter. I can tell that there is no power on the slave when the key is off and motor cranking over (checked it with a VOA).I must be missing something. Has anyone had trouble like this?
Thanks Outboardman
Old Dec 6, 2007 | 01:06 PM
BRETM's Avatar
Default RE: Starter sticking on power stroke
Do you have power at the solenoid wire while this occurs? Could be an internal short in the starter. Or possibly ignition switch?
Old Dec 6, 2007 | 09:38 PM
Thanks I'll check the starter for internal short. Power is droping out when key is turned to the run postion. It has to be in the starter. I'll let you know.
Old Dec 9, 2007 | 04:22 PM
I found "trace" voltage my starter sol assy. No power in the off postion but I have 5.9VDC in the run postion. I have a bad key switch. I assume there is a box on the steering tube that houses the key switch.
Old Dec 26, 2007 | 06:32 PM
Put the new switch on the old girl and it took care of the problem. She cranks each time and quits when the key is back at the run postion. Thanks for the help!
Chase Graham
Mar 1, 2009 01:27 PM
fjw
Dec 30, 2006 06:20 PM
Roanbadger
Jul 1, 2006 12:07 AM
schwede42
Mar 22, 2006 09:41 PM
schwede42
Jan 1, 2006 12:35 AM
