Clunck in front when when turning???
Hello all,
Im a new guy looking for insight. I have a '06 500 CVT, AWD limited with 90000 miles, , i noticed yesterday evening when backing and turning the wheel i heard this clunk. It was when i had steering wheel turned all the way( backing out of my fathers drive way). When i pulled in to my drive way i tried to reproduce the noise and got a little clunk, ( had wheel turned all the way again). I checked my PSF it was at the min line, I filled it up. turned the wheel back and worth when in park and no noise! but when i started to back up BOOM there it was again. I only hear it when the wheel it turned all the way, other time. Im just lost. So my fellow 500 Drivers, can you shed a little insight on to my situation |
Best guess. Aside from a fluid leak and air in the line.
CV, constant Velocity joint needs to be serviced or replaced. Any torn boots? Or your slamming by turning too hard, the moving part into the block that is welded in place to stop you from turning too far and wrecking a CV joint. Again best guess.Throw a couple of jack stands under the front end of her and have somebody turn lock to lock with engine running and listen for the clunk. Keep it in park so you don't drive off the jack stands. If there is no noise then it may be the CV joints when they are driving the wheels and that probably means something in the CV joint is coming apart. skip. |
if its in the front end im thinking it could be your strut tower bushings!! mine started doing that!! i poured a but of tranny fluid ontop of the strut tower under the hood, it stopped!! they were dried out :(
but that was more of a binding kind of thud like when u max out your steering
Turns out it was my Steering stoppers!! passenger side wore out and turned so much it made the spring turn!! hence the binding sound!! new Stoppers and its ok now!!
I have a 2006 ford five hundred limited - I noticed when I put my car into drive that it will lurch forward. What could be causing this?
Originally Posted by Cj Hutchinson
(Post 78156)
Which side does the sound seem loudest?
Originally Posted by Johnnyrama60
(Post 119769)
... turn the wheel all the way, I'm hearing a " creeching" type noise. I had a mechanic look at it, they could hear the noise but could not duplicate it ...
Daughter-in-law's Honda makes such a sound when turning if fluid is low. |
| All times are GMT -5. The time now is 05:16 AM. |
