Ford 500 A.C Problem. Plz help
Old Sep 14, 2018 | 08:13 PM
Mattj62387's Avatar
Default Ford 500 A.C Problem. Plz help
I have a 2007 Ford Five Hundred, 3.0L DOHC Duratec V6 with the 6spd Trans. My problem is that the A.C Compressor does NOT come on. I am very mechanically inclined and here's the process I've done this far.
*I've tested the 2wire (green/black) to the A.c clutch and is has NO power to it.
*I've check ALL fuses and relays. More then once
*I've replaced the A.C pressure switch(3wire on the compressor line)
*I've replaced the Cabin Air temp sensor, located in the EVAP box.
*I've checked the A.C Freon level. Not running I can't get an accurate read but it has enough to start
I still get NO power to the A.C clutch this is won't engage. Can anyone help me plz? Thank you so much
Old Dec 13, 2018 | 08:13 PM
saemetric's Avatar
Is the charge correct
Mattj62387
May 23, 2019 12:11 PM
romeodz
Jul 12, 2014 02:08 PM
highlander
Aug 8, 2012 10:05 PM
JamieA
Jul 19, 2012 06:54 AM
Schuppepartyof10
Jul 1, 2012 06:42 PM
