ford 500 cvt question
I just purchased a 2007 ford 500.with 120,000 miles on it. The car runs great in drive, but here's the problem. There isn't any reverse! I changed the fluid and that didn't help. Did anyone else have that problem? And what did you do to fix it? Was the solenoids in the valve body of the tranny bad??
Originally Posted by randy4jc
(Post 131257)
...but here's the problem. There isn't any reverse! I changed the fluid and that didn't help.
So on your fluid change, did you, or prior owner, use a non-Ford fluid? :confused: This CVT takes a special fluid (which says is incompatible with every other tranny fluid). is only available at Ford dealers, It's light blue-green in color and a Volvo product because the tranny is a Volvo unit. Luck. |
