Ford Flex This new crossover offers the interior room of a minivan with the vintage design of a classic panel truck.
3rd Row seat belt replacement
Old Aug 23, 2021 | 11:28 AM
titanite's Avatar
Default 3rd Row seat belt replacement
Hello,
Has anyone replaced the 3rd row seat belt on a flex? Our puppy chewed both 3rd row belts. I replaced the passenger side (T50 was all that was needed), but the drivers side seat belt retractor bolt (the T50) is buried behind the rear AC unit. The silver circular item (No idea what it is actually called) is right in the way. Has anyone devised a successful plan to change this with out removing the AC unit? I called FORD, they approximate the job at 6 hours of labor as they need to remove the AC unit. There has to be an easier way (I hope).
Thank you in advance!
Old Aug 23, 2021 | 03:42 PM
scott.butler4's Avatar
Workshop manual says you have to remove the aux ac housing, I dont see a way around that unfortunately. If you post some close up pictures we may be able to help more.
Old Aug 23, 2021 | 04:00 PM
titanite's Avatar
Hi,
I appreciate your reply. I purchased the service manuals (and electrical manual (3 in total)), the only thing I found was, "Similar to passenger side". Do you know what section or page it refers to removing ac housing? thank you!
Old Aug 23, 2021 | 07:17 PM
I don't know how your manuals are set up, I can copy and paste the ford workshop manual if you'd like, you will need to evacuate the AC and drain the coolant.
Old Aug 24, 2021 | 08:18 AM
titanite's Avatar
I was able to find it when I went looking for Aux AC, rather than seat belts. What a PITA! Going to have to book a weekend for this one! Thank you for your help.
Old Aug 24, 2021 | 12:08 PM
Good luck. Have a shop evacuate and recharge the AC system
titanite
Aug 4, 2021 08:52 AM
bubble0304
Oct 18, 2012 10:01 AM
curtis_98
Nov 5, 2011 06:50 PM
davidjr92
Mar 17, 2008 07:11 PM
menace
Mar 16, 2008 11:34 AM
