Ford Flex This new crossover offers the interior room of a minivan with the vintage design of a classic panel truck.
Heater
Old Mar 1, 2024 | 10:00 PM
Jamesjk70's Avatar
Default Heater
Need a picture of heater core hose arrangement. Had a hose bust, replaced with new hose set but no heat now. I may have got them in wrong order. Cannot find a decent diagram or pic anywhere. 2010 ford flex limited
Old Mar 2, 2024 | 01:00 PM
In either case the heater core should provide heat,,,,unless,,, it has air trapped inside and the coolant can't circulate through the core. Efficiency would be slightly reduced if hoses are reversed, no big deal.
If you can , do this with the engine not HOT !
With the engine idling , loosen the highest or return hose ,just enough to allow the air to come out and some coolant too, then secure it and that will allow the trapped air to escape. Should take care of the problem,,,,,provided the thermostat is functioning correctly.
degar1877
Jan 2, 2014 07:00 PM
ac917x
Apr 16, 2012 06:33 PM
77ford400
Oct 4, 2011 07:15 AM
77ford400
Jun 1, 2010 01:00 PM
golferguy
Dec 19, 2009 08:02 PM
