Ford Flex This new crossover offers the interior room of a minivan with the vintage design of a classic panel truck.
po301 code
Old Apr 4, 2022 | 07:30 PM
baker018's Avatar
Default po301 code
Have a 2011 e-series van that on occasion check engine flashes for 30 to 40 seconds then goes out.Ran a scan and found a po301 code. Mechanic changed out all spark plugs, wire harness and coil pack for cylinder 1 plus did a fuel induction service. This did not correct the problem. The engine runs fine otherwise.
Old Apr 5, 2022 | 04:00 AM
raski's Avatar
You paid him to solve your problem, he did not fix it. I would take the car back to him.I hope he also changed the coil's boot and used OEM parts since aftermarket coils can be questionable in quality. Coils can be easily swapped for testing. Things to check/try is to swap the #1 fuel injector with another cylinder. Check injector #1 wiring and the coil wiring for #1. A intake manifold leak could be causing a lean miss for #1. Lastly, perform a compression test of all cylinders.
oldtrumpet
Jan 17, 2016 06:38 PM
will1
Jul 24, 2011 09:15 PM
tssb4
Mar 3, 2009 10:26 AM
site2site
Feb 21, 2008 03:18 PM
Doyle
Jul 19, 2007 08:53 AM
