Ford Flex This new crossover offers the interior room of a minivan with the vintage design of a classic panel truck.
Replaced Transmission, need to program solenoid body strat.
Old May 29, 2022 | 03:04 PM
durriej's Avatar
Default Replaced Transmission, need to program solenoid body strat.
2010 Ford Flex 3.5 Ecoboost 6F50 transmission.
I recently replaced my transmission in the Flex. The new solenoid body does not match what was previously in the vehicle. I need to program the solenoid body strategy. I have ForSCAN but it doesn't seem to have the ability to program the solenoid body strategy. Without having to tow the vehicle 40 miles to the nearest dealership and spend the $220 they want to program it, do I have any other options? Any help is greatly appreciated thanks!
Old May 29, 2022 | 04:26 PM
Did you try disconnecting the `battery and discharge the capacitors by holding the negative cable end on the positive cable end for a few seconds , then reconnect the negative cable back on to the battery, start the vehicle without touching the the throttle pedal for a few minutes to allow idle to set, then drive it normally for a few miles with all normal driving . It should relearn your driving habits during that time.
Old May 29, 2022 | 04:28 PM
durriej's Avatar
Doing the relearn drive test isn't the problem. The solenoid body on the new transmission is not the same as the old transmission. So the solenoid body strategy and ID needs to be programmed before you can relearn the shift patterns and that is where I am stuck
Old May 30, 2022 | 11:10 PM
PCM contains the SB strategy/ID and has to match the service tag on the SB/trans. A mismatch, possibly a trans shop that has VCM/IDS capability if any closer, or a lower cost option.
With Forscan,, did you have an Extended License ? If so,, there was no Transmission Characterization Update option?
13 F250,
Old May 31, 2022 | 07:14 AM
durriej's Avatar
13 F250, https://www.youtube.com/watch?v=ywonL52c3N8
The options is not there in FORscan on this model year from what I understand
Old May 31, 2022 | 04:49 PM
Under Forscans granted "Extended License Agreement ' it's not listed as a programming option?
From what you understand?,, meaning someone with a Forscan Extended License checked for you?
Or, you requested the Extended License and it is not there/missing in the module programming selections?
Old May 31, 2022 | 06:05 PM
durriej's Avatar
i have the extended license there is no option for TCM or changing the transmission tables.
grumpyone
May 20, 2020 10:38 AM
bluewind
Jul 18, 2016 07:22 AM
3bautosanford
Feb 13, 2012 03:24 AM
F250232
Oct 28, 2010 01:45 PM
Bill/Carson
Apr 22, 2008 06:53 PM
