2007 Ford Focus Stuck in Park and no brake lights
I have changed the brake sensor and all the bulbs. Still stuck in park and no brake lights. HELP!
Did you check the stop lamp fuse in the central junction box (CJB) ? 10 amp/position 42..
If you have a 12v test light (?) would be very helpful..
If the fuse checks out to be good, check the wire going 'in' (GN/WH) to the brake pedal position switch for 12v,, if 12v is there going in, depress the pedal and check the GR/RD wire for an output voltage.. Sometimes the harness pigtail will break from bending/flexing.. Let us know what you find..
maxpower
Jun 24, 2013 08:58 PM
cameodiypupil
Mar 9, 2011 03:11 AM
caper74
Apr 25, 2008 01:11 AM
