Cooling fan not turning on
Old May 26, 2021 | 06:12 PM
  #21
scott.butler4's Avatar
Ok disconnect the fan connector, remove both relays, remove fuses 16 & 17, install new fuses in place of 16 & 17 using the correct size fuses.
Now check with key on if there is 12v at pin 3 of both relays in the fusebox.
Old May 26, 2021 | 06:55 PM
  #22
nwachai's Avatar
Replaced the fuses 16&17. Removed both relays. No 12 volts on PIN #3 of either relays with key on.
Old May 26, 2021 | 09:57 PM
  #23
Check for voltage at the fuses.
Old May 26, 2021 | 09:59 PM
  #24
nwachai's Avatar
Both fuses have 12 volts
Old May 26, 2021 | 10:04 PM
  #25
So if you have 12v at both fuses but do not have 12v at either relay pin 3 then there is a issue in the fusebox.
You could try and open the fusebox to inspect the internal wiring.
Old May 27, 2021 | 12:03 AM
  #26
nwachai's Avatar
I will do that over the weekend. And thanks so much for your help.
Old Jun 1, 2021 | 06:45 AM
  #27
nwachai's Avatar
Hello Scott,
First of all, I would like to heartily thank you for your technical assistance in helping me to resolve the "cooling fan not turning ON" problem. I really admire your patience with me in resolving this issue. I opened the fuse box and discovered that the 12v cables in fuses 16 and 17 had loosened. I fixed that and all is well.
kubbie
Jul 30, 2012 09:34 PM
pilleway
Feb 28, 2011 10:48 PM
dang482001
Jun 29, 2007 10:36 AM
brewcrew
Jul 9, 2005 03:50 PM
schlepie
Jun 6, 2005 11:50 AM
