ford focus 2007 no start no cranck
hi,
my ford focus automatic transmission have no ignition. when i turn on the switch dash lights become on but when i turn it to ignition there is no click i checked battery is ok and when i give ground current to solenoid relay manually starter worked and engine moved but didn't start. ignition relay and solenoid relay have no ground current and the ground current coming from ecu. and in dash meter a red light caled pats light is flashing always first one or two minute flashing normaly and after ones flash 2 time them three time (2:3) and this flashing continuous until key is at on position.
before my car have some missing in running then i give to a mechanic for plug changing i don't know what he did car is completly stop.now ford authorized dealer demanding $2000 for repairing. plz give me any solution what will i do to start my car. plz. plz. i haven't enough money and my car is still on installment.
i don't have an other key.i changed ecu and gem module once car cranked but after again same problem. will you tell me which module is controlling key code?can i change that device?
The PCM has to be reprogrammed to accept the old key code. It should be done by a dealership.
On your vehicle the onboard computer (PCM) controls the PATS . Not too many places have the equip to do this. You might have some luck with a locksmith . Some of them can do this and possibly for a lot less $$$.
You have two choices.
Either get the replacement ECU/pcm programmed for your only key or get the key and key tumbler from the vehicle where the replacement ecm came from. The PATS system is controlled by the PCM and will prevent the starter from working & the fuel injectors from injecting.
mykillove
Apr 29, 2008 09:01 AM
