Low Fuel Pressure
Old May 25, 2011 | 07:39 AM
pilleway's Avatar
Default Low Fuel Pressure
I do have a 2005 Focus that has a low fuel pressure of 24 psi, to me it seams to be low, to my knowledge it looks that there should be about 35 psi minimum, I looked in to the fuel pump and measured the fuel pressure directly in the outlet and it reaches at least 50 psi. then I looked in to the fuel pressure regulator and had a chance to replace it and still have 24psi.
Has someone experienced the same problem?
Is there any return restriction vavle in the return line that might be not working properly?
Any help or recomendation will be appreciated.
Have a nice day.
Old May 25, 2011 | 06:27 PM
way2old's Avatar
Is there a possibility the fuel filter may be partially clogged?
Old May 26, 2011 | 06:38 AM
pilleway's Avatar
Way2old, thanks for the suggestion!
I have replaced the fuel filter too. I looked in to the fuel pump and all looks OK, I had a chance to try a different fuel regulator and still had the low pressure.
Yesterday I looked in to the fuel pump again and replaced but now I got 100 psi and looks like the fuel return line was blocked. I will look in to the fuel lines conection now.
Thanks.
Old May 27, 2011 | 07:53 AM
pilleway's Avatar
I looked in to the fuel lines by blowing air through them and all looked OK, when I got to the fuel rail I removed the fuel pressure regulator and blowed air through the piping and found partially pluged so I remove the plug with air and problem solved, now I got 50 psi regulated and no problem.
way2old thanks for your recomendation.
Have a nice day.
Old Jun 8, 2011 | 04:29 PM
Bills86e's Avatar
Either the pump or regulator is bad.
Old Jun 9, 2011 | 07:14 AM
pilleway's Avatar
Thanks for the comments and suggestions!
What I did was, replaced the pump and found out that the pump did not had the check valve, so I replaced it and cleaned the fuel rail since it had a rust plug in it and the pressure came back and the vehicle run well.
Thanks to all for the comments and looking.
Have a nice day.
Old Jun 28, 2011 | 06:19 AM
Delacruz8641's Avatar
Here knowledgeable description has given here to regulate fuel by controlling fuel pressure .Especially fuel pressure is playing an important role in circulation of fuel.So it will definitely help me.
Old Jul 9, 2011 | 10:50 AM
jessy's Avatar
his is a collection of seven stories of the American Deep South, set in fictional Ford County, Mississippi. Master thriller writer and worldwide No.1 bestseller John Grisham takes you into the heart of Americas Deep South with a collection of stories connected by the life and crimes of Ford County: a place of harsh beauty where broken dreams and final wishes converge. A mercy mission that is hilariously sidetracked by human weakness; a manipulative death row inmate with one last plea; a small town divorce attorney who suddenly hits pay dirt; a man that sets out to break a casino to revenge a broken heart; a kidnapped lawyer who is confronted with one of his previous cases at gun point; a conman who preys on the rich and elderly; the boy dying of AIDS who finds mercy across the tracks in downturn Clanton: the sum total of human life is brilliantly captured in Grishams unique evocation of lives lived and lost in Mississippi. Frequently moving, often hilarious, and always entertaining, Ford County brims with the same page-turning quality and irresistible narrative of his previous bestsellers, and is proof once more why John Grisham is our most popular storyteller.
surferjoegomango57
Dec 11, 2013 02:32 PM
thalchak
Mar 20, 2013 11:42 AM
Michael Leonard Woodcock
Dec 10, 2012 08:36 PM
Southwind13
Mar 26, 2009 11:49 AM
gill_plate
Nov 19, 2006 01:38 PM
