No tail or instrument lights - uggg
Old Feb 12, 2013 | 02:29 AM
hyp05fxdl's Avatar
Question No tail or instrument lights - uggg
On my g/f 2005 Focus stationwagon, no lights on the instrument cluster & no tail lights when the lights are turned on (both sides). All the fuses are good. The light bulbs are good (even swapped in a new one) and the hazards, turn signals & backup lights still work.
Any ideas? Thanks
Greg
Old Feb 12, 2013 | 10:14 AM
Welcome to the site Greg..
Make sure the fuse in the Central Junction Box (CJB) in position 30 10amp is good. Its the power feed for the H/L switch for tails and panel illumination. There a couple others there for tail lamps/license but if you have a total black out at the back, sides. license, then its either the (30-10amp) or possibly the H/L switch itself. If the fuse proves out good (check for power distribution with a test light on both sides of the fuse) then the next step would be to pull the H/L switch and check/back probe the connector for 12v both coming in, and out of the switch 'prior' to a replacement.. If the fuse checks out, and you want to do some checks at the H/L switch or need help removing it, let me know...
willy j
Oct 9, 2025 03:02 PM
lauraj
Sep 25, 2012 11:23 AM
MikeMurphyinKY
Jan 9, 2007 03:00 AM
tstout
Jun 25, 2006 04:04 PM
BlackandChrome
Feb 20, 2006 01:05 AM
