what is problem with no reverse only periodiic on my 2013 focus after warm works well
Old Mar 19, 2022 | 10:03 PM
ehodrod13's Avatar
Default what is problem with no reverse only periodiic on my 2013 focus after warm works well
what can be cause of problem
Old Mar 20, 2022 | 05:16 AM
raski's Avatar
Might be worth dropping the pan for a look inside. A clogged filter might allow more fluid to pass after its warmed up.An internal solenoid might be acting up.With a neglected transmission, metallic debris often is drawn magnetically to the solenoids. If you find a lot of debris on the pan's bottom, your likely looking at an overhaul.
Austin Cymbalski
Mar 21, 2021 07:50 PM
Fourder
Oct 17, 2013 08:15 PM
SM Darby
Jun 27, 2013 08:28 PM
focus123
Feb 6, 2013 02:41 PM
