1999 Ford Explorer
Old Jan 13, 2018 | 06:40 PM
donbola's Avatar
Default 1999 Ford Explorer
So I had a problem with my car today.
The tail lights have been not working so we bought a new fuse today. When we inserted the fuse into #11 of the power distribution box the tail lights turned on but the tail lights wouldn't turn off when we turned off the lights. We had to take the fuse back out to turn off the light. I'm not sure whats wrong.
Break lights work but tail lights don't.
Instrument cluster lights don't work as well as well as the speedometer.
Old Jan 13, 2018 | 06:57 PM
donbola's Avatar
Here's the manual if anyone needs to see that
https://justgivemethedamnmanual.com/...owners-manual/
Old Jan 15, 2018 | 10:44 AM
greasemark's Avatar
More info would be helpful; Do the turn signals work properly, as well as the 4 way flashers?
From how I read this, the taillights won't shut off but the interior illumination is inop. Is this correct?
Old Jan 19, 2018 | 06:28 PM
donbola's Avatar
Yes the turn signals do turn on
The only problem was the tail lights that don't turn on.
The instrument cluster lights never turned on as well, might just be broken
When we insert the fuse the tail lights will turn on as well as the front lights.
But the front lights and tail lights won't turn back off until the fuse or battery is disconnected
Old Jan 21, 2018 | 01:18 PM
greasemark's Avatar
These use a relay; could be a problem with the relay either not powering up or getting told to power up. It should be in the rear of the luggage compartment either near the jack equipment or the top package tray. its been a long time since I've had to fix one.
crbnintegra
May 23, 2007 12:01 PM
ptownsend
Dec 17, 2006 03:39 PM
mystiquegoddess
Nov 7, 2006 01:38 AM
BillV63
Jul 23, 2006 06:55 PM
mystiquegoddess
Jun 14, 2005 01:49 AM
