2000 E250 oil pan replacement
I have a crack in the oil pan where it is sitting on the cross member. It appears the oil pan is being crushed by this. Will new motor mounts fix this. Also I tried to remove the old one. Do I have to remove the transmission to get the pan out on this vehicle?
Sagging or broken motor mount(s) is one possibility . Which engine do you have?
Originally Posted by raski
(Post 135307)
Originally Posted by Dreww2112
(Post 135308)
I have 5.4 l with 4r70w transmission
While it is apart, it is up to you the do some inside checking. Myself, I would install a new oil pump and plasti-gauge the bearings to see if they are good enough for further use. You will need a torque wrench for that.... Good luck. |
