2006 Ford E-150 Runs rough
Old Apr 22, 2011 | 06:22 PM
agoodname's Avatar
Default 2006 Ford E-150 Runs rough
This van has a slight misfire with no codes
What has been done so far...
-Vacuum checked
-Changed coil pack spark plugs and wires
-Leak down check on cylinders
-EGR valve has been replaced
Strange when running at idle slight misfire and fuel pressure shows 5 lbs fluctuation that coincides with the misfire.
Fuel pressure is 30 to 40
Power checked in gear at all speeds and still no codes.
Old Apr 22, 2011 | 06:36 PM
How long have you had this condition? When was fuel filter changed? Possibly some water in the fuel? Check out of crank sensor? Have you been able to determine if misfire is in one particular cyl or varies?
Old Apr 22, 2011 | 07:13 PM
agoodname's Avatar
For months
Fuel filter was changed
No water in the fuel.
Misfire is very subtle and varies.
Old Apr 23, 2011 | 12:37 AM
Which engine do you have in it?
Old Apr 23, 2011 | 01:18 AM
agoodname's Avatar
4.6 liter
Old Apr 23, 2011 | 05:34 AM
Have you tried to either pinch off the vacuum to the EGR valve or remove and plug that hose and see if you get any improvement.
Screenwriter
Dec 8, 2016 08:37 PM
goatsauce
Apr 15, 2013 08:32 PM
tazzy
Aug 29, 2010 09:08 PM
louchris
Nov 29, 2007 11:58 AM
