Battery not Charging
hi all any help would be greatly appreciated
i have a 2011 Ford Fiesta Zebec 1.4 Automatic its not charging the battery i have replaced the alternator with a brand new one i have also replaced the battery with a new one and still not charging any ideas thanks |
Welcome Paul on FF-Forum.
Here some solution why battery is not charging: Solution #1: Focus on your battery first. If your vehicle has stopped running, jumpstart the engine, remove the jumper cables as quickly as possible, and wait. If the vehicle keeps running after a period of time, there’s likely a problem with your battery. Take into account the outward appearance and age of the battery when deciding whether to replace it. Also, inspect your battery cables and make sure they are in good shape. Bad cables will not deliver the full current flow needed to operate properly. Solution #2: If the battery won’t hold its charge and your engine stalls out, then it’s time to turn your attention to the alternator. Although your battery may have enough energy to get the engine fired up initially, it will eventually lose power if it is not being recharged by the alternator. Here are a few quick ways to pinpoint a bad alternator:
There have been problems with the plug that plugs onto the alt. The inner contacts don't make good connections and can send you on a wild goose chase . Make sure they are clean and tight.
(Post 98054)
