Battery not Charging
Old Jun 14, 2016 | 12:55 PM
Paul Shiels's Avatar
Default Battery not Charging
hi all any help would be greatly appreciated
i have a 2011 Ford Fiesta Zebec 1.4 Automatic
its not charging the battery
i have replaced the alternator with a brand new one
i have also replaced the battery with a new one and still not charging
any ideas thanks
Old Jun 14, 2016 | 01:42 PM
Shay_Fox's Avatar
Welcome Paul on FF-Forum.
Here some solution why battery is not charging:
Solution #1: Focus on your battery first. If your vehicle has stopped running, jumpstart the engine, remove the jumper cables as quickly as possible, and wait. If the vehicle keeps running after a period of time, there’s likely a problem with your battery. Take into account the outward appearance and age of the battery when deciding whether to replace it. Also, inspect your battery cables and make sure they are in good shape. Bad cables will not deliver the full current flow needed to operate properly.
Solution #2: If the battery won’t hold its charge and your engine stalls out, then it’s time to turn your attention to the alternator. Although your battery may have enough energy to get the engine fired up initially, it will eventually lose power if it is not being recharged by the alternator. Here are a few quick ways to pinpoint a bad alternator:
  1. Crank over the engine, turn on your vehicle’s lights, and observe. If they start bright and then slowly fade, your alternator might not be delivering the proper charge to operate your vehicle accessories.
  2. If your vehicle is already dead, jumpstart the battery and wait. If the alternator is bad, your car or truck will eventually die out again as the battery is not re-charged.
  3. Get a good-quality voltmeter or multimeter and test your battery’s state of charge. The voltmeter should read around 12.6 volts with the engine off and 14-15 volts when the engine is running. If voltage is below 13.5, there’s a good chance the alternator is not keeping up with your battery’s charging needs.
Solution #3: Check the alternator cables for abnormal wear, including cracking and fraying. Replace or tighten the cables as necessary.
Old Jun 14, 2016 | 03:48 PM
There have been problems with the plug that plugs onto the alt. The inner contacts don't make good connections and can send you on a wild goose chase . Make sure they are clean and tight.
Old Jun 15, 2016 | 11:26 AM
Shay_Fox's Avatar
Great post hanky. Agreed with you, you have to clean all things and tight !!
JayB954
Dec 14, 2009 05:36 AM
djporche
Mar 12, 2009 11:09 AM
monie_love06
Jan 22, 2009 11:04 AM
huck
Nov 27, 2007 02:50 PM
seanny77
Oct 19, 2006 12:52 AM
