need help with brake lights please
Old Jan 6, 2017 | 09:17 PM
benb81's Avatar
Default need help with brake lights please
ive replaced my brake pedal switch and my brake lights are still staying on. the only way they turn off is when i pull the fuse
Old Jan 7, 2017 | 02:27 AM
If you have access to a test lite or voltmeter , check the wires at the switch. One should have power all the time and the other should only have power when the pedal is depressed, providing you have the correct wires. Some switches also are in the cruise control circuit to cancel cruise when you depress the brake pedal.You may need to adjust the position of the switch to get the proper result.
willy j
Oct 9, 2025 03:02 PM
no1toolman36
Oct 23, 2009 10:13 AM
marty
Dec 5, 2007 12:23 PM
marty
Dec 5, 2007 12:22 PM
moonunitpurple
Mar 8, 2007 09:51 AM
