Need help/info with amp for Shaker 1000 subs
Old Sep 15, 2019 | 11:07 AM
Thegreatestdude's Avatar
Default Need help/info with amp for Shaker 1000 subs
A few years ago i got a used shaker 1000 speaker system from an old mustang along with an amp. I have no idea what kind of power the amp puts out or how to wire it. If it helps the model number is AR3T - 18C808 - DA. Please help
Old Sep 16, 2019 | 02:51 PM
Welcome to the site..
The subs and amp are from a 2010 Mustang..
Amp control is through the Audio Control Module which you don’t have. You could use an aftermarket amp with the OE subs.
I emailed you the schematic as well as the connector view. Double check the wire colors/tracers for accuracy..
durasel
Apr 23, 2008 06:09 PM
QSGTO
Jan 26, 2007 11:03 AM
