PCM Trouble Codes
Replaced the heads on my 2005 Explorer, Since then I does not run right. Ran a diagnostic check and found the following codes,
https://cimg0.ibsrv.net/gimg/www.for...4c724d6b93.png I need to determine if the PCM is bad or not. Please help. Moe |
We don't usually go after a PCM until we rule out all other possible causes.
Can we ask what was the original problem that required the heads to be replaced? |
