PCM Trouble Codes
Old Dec 10, 2022 | 09:44 AM
Möęčãnic's Avatar
Exclamation PCM Trouble Codes
Replaced the heads on my 2005 Explorer, Since then I does not run right. Ran a diagnostic check and found the following codes,
I need to determine if the PCM is bad or not. Please help.
Moe
Old Dec 10, 2022 | 11:27 AM
We don't usually go after a PCM until we rule out all other possible causes.
Can we ask what was the original problem that required the heads to be replaced?
FreshLee14
Mar 29, 2018 11:59 AM
CarletonFord
Aug 14, 2015 07:20 AM
Luke Jeffrey
Aug 28, 2014 03:29 AM
obd-trouble-codes.com
Oct 6, 2011 05:37 PM
Donald97
Aug 24, 2011 03:29 AM
